Bump..
Forged 4340 I beam connecting rods, rifle drilled, 20mm pin size, genuine arp bolts and balanced to +-1 gram. Can also come with calico coated acl bearings.
1.8T 20V with OEM & aftermarket pistons
Engine Codes: AEB, AGU, AMK, AMU, APX, APY, ATC, AYP, BAM, BEA
1.8T 20V with aftermarket pistons only
Engine Codes: AMB, ARX, ARY, ATW, AUM, AWM, AWP, AWW, BJX
2.0T FSI EA113 with aftermarket pistons only
Engine Codes: AXX, BGB, BPG, BPJ, BPY, BUL, BW, BWE, BWT, BYK, BHZ, BYD, BZC, CDLA, CDLB, CDLC, CDLF, CDLG, CDMA, CRZA
2.0L 8V with afermarket pistons only
Engine Codes: AEH, AZG
1.8L 8V with OEM & aftermarket pistons
Engine Code: JH
1.8L 8V G60 with aftermarket pistons only
Engine Code: PG
2.0L 16V with OEM and aftermarket pistons
Engine Codes: 9A, KR, PL
Willing to post
$600 a set
91' Golf mk2 GTi 1.8t (soon to be gtx3076’d)
Golf mk2 GTi 8v
02' Audi S3 (soon to be gtx3076’d)
Bump..
Golf mk2 GTi 8v
Plenty of sets available
Golf mk2 GTi 8v
1.8t drop in rod kit available.
20mm rifle drilled rods
Standard elring head bolts
Standard elring head gasket
Calico coated acl rod bearings
Standard Götze piston rings
$1060
Golf mk2 GTi 8v
